Would the egr cause.....
Old Aug 22, 2003 | 11:46 PM
NeoSNK's Avatar
Would it cause the car to jerk when cruising? I know its bad and I plugged it. But I still have a problem with it. Does it have to be removed? It only jerks when its hot out. At night its fine. Its not running to hot but I think the opti might be getting heat soak. It is a new opti though. Or could the egr cause this? It idles fine but when I take off its kinda jerky. Its the same at cruising speed.
Old Aug 23, 2003 | 07:46 AM
A stuck open EGR can cause a rough idle and surging during cruise. However, if what you are feeling is sudden and intermittent, it's probably ignition related.
Old Aug 23, 2003 | 10:19 AM
NeoSNK's Avatar
Well I have a new opti, new coil, new wires, and fairly new plugs(10k miles).
Old Aug 23, 2003 | 06:05 PM
Izod's Avatar
is it pulling a code? i know my EGR did something similar and it ran much smoother after i replaced it (althought i can't say how much smoother because i did LTs at the time which cause the car to shake a bit... heh). it was a $70 part and an easy install. may be worth doing just in case. also check for arcing at night. just some thoughts.
Old Aug 29, 2003 | 11:08 PM
NeoSNK's Avatar
I'm gonna replace the plugs but I keep getting the engine light when on the highway. The egr is plugged, do I need to plug both lines going to the egr solenoid? I tried unplugging the elctrical connector and the engine light came on right away.
Old Aug 29, 2003 | 11:55 PM
Just cap the vacuum line at the manifold (the one that feeds vacuum to the solenoid).
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
