WOULD this car make 475 hp...
Old Jul 11, 2005 | 11:01 AM
glennxx1's Avatar
94 lt1 6 spd
• ATI 600b Procharger with intercooler kit currently 8 lbs boast ). • Custom hard intake with mass air on blow thru side. • 42lbs/hr fms fuel injectors • Racetronix high pressure/high Volume fuel pump with hot wire kit. • K&N air filter. • Alky Controls progressive alcohol injection system • Competition Cams CC30-5 cam 220/230 .510 lift 114 lsa • ex 612 springs • 1.6 self aligning roller rockers • AFR hydra rev kit • keyed crank hub • SLP shortie headers • SLP off-road dual 2.5” y pipe • BORIA adjustable exhaust.
Old Jul 11, 2005 | 11:28 AM
Bow94z's Avatar
Re: WOULD this car make 475 hp...
are you talking flywheel hp or Rear wheel hp?
Old Jul 11, 2005 | 11:34 AM
jerminator96's Avatar
(14.7+pounds boost)/14.7*starting hp =hp after boost
If all of those upgrades gave you in the neighborhood of 325hp then the 8pounds of boost would get you around 500hp. There is about a 16% drivetrain loss that you need to factor in for flywheel to rear wheel conversion. But the more hp you make, the lower the percentage.
Old Jul 11, 2005 | 11:40 AM
glennxx1's Avatar
fly wheel ya
Old Jul 11, 2005 | 05:30 PM
slimdawson's Avatar
Yes it can. Mine makes approximately 530 at the flywheel and I have a stock long block with bolt-ons and no alcohol. That is also 8.5#.
Ken Cemo
Jan 27, 2015 08:45 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
