Would a bad air pump cause....
Old Jan 21, 2005 | 11:30 AM
Guy's95Z's Avatar
Would a bad air pump cause a car to be running and then just cut out?
Old Jan 21, 2005 | 11:54 AM
Re: Would a bad air pump cause....
No. The AIR pump only runs at startup for a couple minutes to heat up the cat(s). No affect whatsoever on whether the engine runs or how it runs.
Old Jan 21, 2005 | 12:12 PM
Guy's95Z's Avatar
I had a check engine light come on and I have had the car to be running smooth and then cut out or I'll go to pass, goose it and it would cut out. The light was for the air pump and there is no more codes coming up. It only does it every once in awhile.... weird... What about bad O2 sensors?
Thanks....
Old Jan 21, 2005 | 02:50 PM
joecool72's Avatar
I had our Chevrolet dealer print a report on my Z28 and I found out I have an open recall on the AIR pump. If you still have yours on the car (others just tear it off) I would suggest first checking out if this recall applies to your car.
You should be able to contact Chevrolet through their 1-800 number or contact a local dealer to do a search for you. Good luck!
Old Jan 21, 2005 | 04:30 PM
blkchevyz's Avatar
i'm one of the people that just tear it off.
if you just unplug it, then make sure the fuse is ok for it your ses light should go away
Old Jan 22, 2005 | 03:34 AM
Ace_437's Avatar
That's exactly what I did. Took about 30 seconds and saved me around $300 that the dealership wanted to replace the pump.
Old Jan 22, 2005 | 10:27 PM
NtenseZ28's Avatar
I have an LT4 and an LT1...both minus the air pump. Both run great, and it just passed Massachusetts State Emissions without it. So I say...save yourself about 5 lbs!
Back on topic...check the opti-crap or fuel pump. If your losing spark or fuel at WOT...that'll do it everytime. Try the basic stuff first and keep us all posted, as we're all willing to help! Is it cutting out at idle or slight acceleration??
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Aug 16, 2002 10:03 PM
