Would 3 in. true duals be overkill for my setup?
Old May 4, 2004 | 07:46 PM
94 CAMRO Z28's Avatar
With the mods in my sig, would 3in. be overkilll? In years to come I would like to do a larger cam and ported heads, but for now its stock heads with hotcam. I guess Im mainly looking to see if 3in. would hurt me a bit vs. say 2.5? I plan on using bullets on each side with a dump before the axle. Thanks
Aaron
Old May 4, 2004 | 08:22 PM
Cmr0z28's Avatar
2.5 will be plenty. 3" duals are more for stroker applications running power adders. 2.5" duals will be equivalent to a single 3.5" pipe.
-Matt
Old May 4, 2004 | 08:25 PM
I realize 2.5 would be plenty, but do you think I would hurt Hp or Tq by going with 3in vs. 2.5?
Aaron
Old May 4, 2004 | 08:50 PM
Birdie2000's Avatar
Do you plan on significantly more mods? As said above, if you're not planning on running a very healthy stroker engine or a power adder, I would just get 2.5". If you're planning on doing such things, it's your call whether or not you should run the bigger pipes now to plan ahead. At this power level you'll probably lose a little low-end by going with 3".
Old May 4, 2004 | 08:57 PM
Well I hope by next year I'll have ported heads and a larger cam. And after that I would like to possibly supercharge...but probably will end up playing with some N20 first
Aaron
Old May 4, 2004 | 09:54 PM
ZDriver96's Avatar
dual 3 inch will see gains over a stock single 3inch at 600+ rwhp
Old May 4, 2004 | 10:47 PM
kmook's Avatar
Advanced Tech Moderator
Re: Would 3 in. true duals be overkill for my setup?
No.
And you will see gains with dual 3" over a stock single 3" at 400+rwhp, what is your point?
Old May 5, 2004 | 08:16 AM
ZDriver96's Avatar
I dont know kmook... U know a lot more than me but my friend Dan put 590rwhp to the ground with a Heads/cam nitrous LS1.. He switched to true duals dumping at the axles and didnt gain any power..
but Come to think of it though Al put true duals on and he was in the 600rwhp range and gained 40 horses to the ground.... hmmm... I still think 400rwhp is to little to see benefits though.
Old May 5, 2004 | 09:31 AM
kmook's Avatar
I am just going off of my personal experiences, and also data that Chuck has provided. http://web.camaross.com/forums/showt...026#post774026
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
Firechicken350
Jun 6, 2015 11:25 PM
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
