Worth replacing 110K mi Opti since it's already off?
Subject pretty much says it...I'd HATE to have to tear this bitch down in another 2000 miles to replace the Optispark. As far as I know it's original. Engine's out for a rebuild.
If I were to replace it, not sure if I'd be better off getting one off Jason Cromer, brand new (Forget what the going price is?), or a used one with maybe a few thousand miles out of the parts forum...I just don't see the sense of sticking this one back in there...
Thanks!
Dave
Thanks!
Dave
I wouldn't even mess around with a used opti. And yes since you have the opti off I would replace it. I'm sure you guys are gonna think this is crazy but my opti lasted fot 159,000 miles. It just recently went. But thats not the case most of the time. I got mine from Jason and everything worked out very nicely. In fact I outwitted the GM dealership and got my wires, opti, timing chain and water pump replaced for $540. Don't count on that ever happening. You're the guy that spun a bearing recently right? How's it coming along and what did you end up doing to the car?
OK a new opti it is.
Yep you are correct in that I spun a bearing. I kinda went a little wilder than I expected on this rebuild, here's what I'm going to do:
http://web.camaross.com/forums/showt...hreadid=134068
http://paradox.shacknet.nu/dave88lx/...uildsheet1.jpg
Crankshaft ~ 9-350-3750-6000-L ~ Scat 9000 Cast 3.75" stroke
Rods ~ 2-ICR6000 ~ Scat 6" 4340 I-Beams
Pistons ~ 138103 ~ SRP Forged 16cc Inverted Dome
Rotating assy is here now, build should start this week
Originally posted by shoebox
For all the money you are spending, get a new one from Jason. When you fire up that new engine, you don't want to have to worry about "what-if this or that is not working right?".
Open up your old opti, and you'll have your answer. The rotor an contacts will be worn, plus the bearing is probably shot.
The opti is really a 100k tune up item, buy a new one from Jason or Dal. Make sure you get it lined up right, make sure you get the plug wires on the right posts, and dont forget to plug in the wiring harnes on the upper passenger side.
A new water pump is a good idea, given the miles and the new opti.
Originally posted by thewinner
Well......I wouldn't be so sure LOL! Tons of people have had dead optis out of the box. I would be pissed if i got one though!
10-31-2016 11:09 AM
grabbem88
03-18-2015 01:25 PM
Alex Barnes
01-24-2015 10:21 PM
