Is this worth 3k? (need answer soon please)
Old May 1, 2006 | 08:08 PM
LenT1's Avatar
Someone is selling the following, am I able to build this myself for 3k without using a core or is 3k for the following setup worth going for. All parts are new and unused except ofcourse the block etc that had machine work done.
Block:
Cleaned, dipped, blasted
Bored .030" over and honed
Align-honed
New Speed Pro freeze plugs, seals, and gaskets throughout
oilpan rail clearanced for stroker crank
Eagle ESP Cast/Steel 3.750" Stroke Crankshaft (Internal Balance) 1 piece rear seal part # 103523750i
6.0" 5140 steel SIR (Full float bushed) rods with ARP bolts (SIR6000BBLW), these rods are clearanced for up to a 600 lift cam
SRP Forged DISHED pistons 10.5:1 with a 58 cc head
Speed Pro Premium Plasma Moly Ring set
Clevite 77 MS909P Main & CB663P Rod bearings
Heads and Other:
Stock aluminum heads: ported on intake and exhaust runners with cleanup work in the bowl area head surface milled, 3 angle valve job, spring heights set
GM Performance Parts LT4 HOT Cam Kit (high performance valve springs, 1.6 ratio aluminum roller rockers, .525"int .525"exh 218/228 at .050" camshaft)
Crane Hi-Energy Roller Lifters
Trick Flow Pushrods
Melling Z28 Hi-Output Oil Pump
ARP Head, Rod, and Main Bolts Used throughout
Old May 1, 2006 | 09:03 PM
MikeTR's Avatar
Re: Is this worth 3k? (need answer soon please)
Is it assembled? If it is, who built it? A shop or the guy in his garage? If you have to build it, I dont think it's an incredible deal. I just brought a Jasper rebuilt (I know not the same, but as a guage) 3yr/75k warranty and it was $2100 (i get the "Jobber" price). Hopefully someone else can help more! LOL
Mike
Old May 1, 2006 | 11:25 PM
LenT1's Avatar
It has been assembled, comes with all paper work, "balance card" etc. It was not assembled by a shop, but suposedly a guy and his father that has built engines for 30 years as they put it. Are the parts themselves with that setup worth the cash, or am I better looking around more?
Old May 2, 2006 | 01:07 AM
pgm's Avatar
pgm
It doesn't sound too bad except I'd be a bit wary of the P-series bearings. I used them in my engine and pulled it after less than 200 miles and they were scorched. But I did have somewhat low oil pressure at idle and the temp skyrocketed once due to a failed electric water pump so that could have fried em. Still they should have been more durable. From now on I'm going with H-series in all my builds...
Old May 2, 2006 | 06:59 AM
LenT1's Avatar
Thanks for the advise. Anyone else care to comment? I know theres better things you can get, im just trying to determine if it is a decent deal.
Old May 2, 2006 | 01:52 PM
yournamehere's Avatar
Mike
Hey,
I'm exploring options for my '96 Z28 right now too. I went on the Jasper
web site, the "regular" LT1 listed for $2800 and the "upgraded" was about
$3300.
Which one did you get ? Core charge, shipping ? The company
I work for has a chain of retail garages, so I should get the good guy
price too. May have it installed as well.
Sorry for hijacking the thread, but I'm close to doing the rebuilt, but would
love a 383. I think the 383 is just out of reach for me.
Daluchman1974
Sep 11, 2015 06:12 AM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
