Worst luck ever oil pan leak!
Old Mar 12, 2004 | 05:51 PM
SLeeper94Z's Avatar
Well I was setting my car back down from reinstalling the tranny
i was letting the jack down and some how from letting it down jack slipped and knocked a hole in the pan , i thought about patching it with jb weld if not too bad,for temp fix.... what do I have to do take off the Oil pan? Is it hard to do ? thanks
Old Mar 12, 2004 | 06:59 PM
That might work, but you would really want to be sure that the pan was not inerfering with the crank in any way.
Old Mar 12, 2004 | 07:10 PM
bdc95ta's Avatar
I just removed my oil pan a couple of weeks ago and yes it is a quite involved job. I need to go back and re-torque the bolts one last time but so far no leaks.
Old Mar 12, 2004 | 09:14 PM
SLeeper94Z's Avatar
oil pan
I jb welded will have to let set up over night...
O god how long would it take to take it off and reinstall another one?
Old Mar 12, 2004 | 09:44 PM
97WS6SCharged's Avatar
I took mine off in about 10 minutes, but I've also got just about everything else off the motor cause I'm replacing the cam and fixing a broken head gasket. Torqing the rail bolts back down looks like it will be the biggest PITA, but atleast they're only torqued to a few ft/lbs.
Old Mar 13, 2004 | 01:03 AM
bdc95ta's Avatar
it took me around 2 weeks but with school and when I'm not at school work and daylight all being issues I only put in a 1/2 hr. here or hour there type thing. Now that I know exactly how to do it I could do it in a day, easy.
-b
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
