worried about new cam - big enough?
Old Sep 15, 2003 | 07:02 AM
magius231's Avatar
I just picked up an XE 230/236 cam, .510/.520 lift@1.5 ratio. I'm a little worried about the lift numbers though, as this is the smallest lift you can get in a 230/236 cam. I know it will be easier on the valvetrain, but is it going to make the power I want? I'm shooting for 400RWHP or so with Lloyds heads and the stuff in the sig. I want to be able to trap around 117 in the 1/4, but is this cam's lift numbers going to hold me back? (I'm using 1.6 rockers, which makes it .544/.555 lift)
Old Sep 15, 2003 | 07:55 AM
joeSS97's Avatar
I would think that cam could get the job done with the right supporting stuff.Including programming.
Old Sep 15, 2003 | 08:22 AM
Fastbird93's Avatar
With a good supporting set of heads, YES you will make 400RWHP.
Old Sep 15, 2003 | 08:23 AM
Shankels94TA's Avatar
That cam should be plenty big for a 350 motor. If its a 112 LSA with a good set of heads you should be near 400HP considering you have longtubes etc.. Sounds like a solid setup to me.
Old Sep 15, 2003 | 10:24 AM
magius231's Avatar
it is 112LSA but I have 1 3/4 shorties not LT's. thinking about going 2 1/2 true duals though to open it up a bit. Has anyone else actually used this cam? I don't really see many people with it....
Thanks again!
Old Sep 16, 2003 | 03:41 PM
magius231's Avatar
TTT - noone else has this cam at all?
Old Sep 16, 2003 | 04:04 PM
BradZ28's Avatar
The previous responses have been accurate. That cam is as big as you can go in a 350 and still not have some pretty serious cam surge IMO. You should get darn close to 400 rwhp with a dyno tune, cutout, long tubes, etc.
Brad
Old Sep 16, 2003 | 05:05 PM
Z95m6's Avatar
I got it and love it. I have no numbers yet but good heads and a 230/236 is good for 375-400 rwhp.
Old Sep 16, 2003 | 06:00 PM
Brandon 95 Z28's Avatar
I was actually in the same boat you are, and decided to get one custom ground with a little more lift.
Brandon
Old Sep 16, 2003 | 06:58 PM
llafro's Avatar
I have the 230/236 with 1.6 like you are considering. I made the numbers in the sig. I think my tune may be a bit conservative, so there may be some more in it. It has a nice sounding lope to it. I managed to scare off a Mustang GT the other day with just the sound of it .
It runs pretty much like stock at low RPM, but just keeps pulling at harder and harder all the way to the red line. I get a very little bit of cam surge at low load, light throttle, but it's hardly noticeable.
BRAD
Old Sep 16, 2003 | 08:13 PM
Z95m6's Avatar
llafro does your car have gears? I just wanted to say our cars are almost identical except the TB and electric water pump. My car was a little sluggish down low before my gears and after them it is an animal. Just thought i would recommend gears if you didn't have them.
Old Sep 16, 2003 | 09:51 PM
magius231's Avatar
Z95m6, tell me about your 8.8 swap, who did it and how much did it cost?
Thanks for all the responses guys!
IgorT.455/406
Mar 12, 2015 03:39 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
