worried about new cam - big enough?
I just picked up an XE 230/236 cam, .510/.520 lift@1.5 ratio. I'm a little worried about the lift numbers though, as this is the smallest lift you can get in a 230/236 cam. I know it will be easier on the valvetrain, but is it going to make the power I want? I'm shooting for 400RWHP or so with Lloyds heads and the stuff in the sig. I want to be able to trap around 117 in the 1/4, but is this cam's lift numbers going to hold me back? (I'm using 1.6 rockers, which makes it .544/.555 lift)
it is 112LSA but I have 1 3/4 shorties not LT's. thinking about going 2 1/2 true duals though to open it up a bit. Has anyone else actually used this cam? I don't really see many people with it....
Thanks again!
Thanks again!
The previous responses have been accurate. That cam is as big as you can go in a 350 and still not have some pretty serious cam surge IMO. You should get darn close to 400 rwhp with a dyno tune, cutout, long tubes, etc.
Brad
Brad
I have the 230/236 with 1.6 like you are considering. I made the numbers in the sig. I think my tune may be a bit conservative, so there may be some more in it. It has a nice sounding lope to it. I managed to scare off a Mustang GT the other day with just the sound of it
It runs pretty much like stock at low RPM, but just keeps pulling at harder and harder all the way to the red line. I get a very little bit of cam surge at low load, light throttle, but it's hardly noticeable.
BRAD
.It runs pretty much like stock at low RPM, but just keeps pulling at harder and harder all the way to the red line. I get a very little bit of cam surge at low load, light throttle, but it's hardly noticeable.
BRAD
llafro does your car have gears? I just wanted to say our cars are almost identical except the TB and electric water pump. My car was a little sluggish down low before my gears and after them it is an animal. Just thought i would recommend gears if you didn't have them.
IgorT.455/406
Mar 12, 2015 03:39 AM
