working on my fuel system
Old Jun 3, 2006 | 07:50 PM
lethal93ta's Avatar
after thinking it over I decided Im going to make things simple, I was going to do the dual intank pumps but decided that Im going to drain the tank and pull it out, Im going to braze a 10 AN fitting to the bottom of it and run a aeromotive A1000 pump ran off a aeromotive controler, from the Pump im going to have 1/2 inch line run up to the 8 AN fittings Im going to have welded to the top of my fuel rail, on the back side Im welding in 2 more 8 AN fittings and running those to the new A1000 fuel regulator and ill have a 3/8 line running back to the tank for the return, I might even use the stock feed line for my return, its going to cost a couple of bucks more but I think this is going to be a much nicer system over all, I started to work on the rails some more tonight, I have to take them to the local shop and have them TIG welded in
DirtyDaveW
Dec 1, 2016 05:37 PM
Jul 4, 2005 05:00 PM
Eric H
Aug 10, 2002 06:39 AM
jwright3SS
Jul 30, 2002 03:49 PM
