Wont stay running after cam swap
Old Aug 14, 2005 | 06:46 PM
  #16
simple's Avatar
Re: Wont stay running after cam swap
if you can sit there with your foot on the gas helping it idle at about 1000rpm or so, and it doesn sound ****ed up...as in backfiring sputtering bad vibrations etc.etc. (stuff really out of the norm) i dont think you will have too much issue with it nad put money on the pcm needing time too adjust for the new cam
Old Aug 14, 2005 | 07:51 PM
  #17
Projectz28's Avatar
Moderator
3/4 past 0 is too tight. Factory is 1/2 turn I usually set mine 1/8 to 1/4 turn.
Old Aug 14, 2005 | 11:18 PM
  #18
Z95m6's Avatar
Does it backfire or anything? I had a similar problem after i had my motor apart and i had just got two plug wires turned around. I don't know why it still wouldn't idle but as soon as you let off the gas it would die.
Old Aug 15, 2005 | 10:53 PM
  #19
SuperDavez28's Avatar
I was mistaken, he did have them at 1/2 past 0. Well Simple was right, we just let it run for about a half hour and now it idles fine. Now all he's gotta do is fix a leak somewhere in the y-pipe then i can take the car. Thanx for the help.
Old Aug 16, 2005 | 12:20 AM
  #20
simple's Avatar
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
F(ast)-body
Feb 26, 2003 09:05 AM
