wont start unless spraying starter fluid
Old Apr 9, 2011 | 06:03 PM
red97rs's Avatar
i found a car for sale, its a rs and it had a lt1 swap... it will turnover but wont start unless you are spraying starter fluid in it...
would this just be new injectors?
or something more
Old Apr 9, 2011 | 06:18 PM
my1994z28's Avatar
Re: wont start unless spraying starter fluid
Maybe the fuel filter,fuel pump,fuel pressure regulator?
Old Apr 9, 2011 | 06:46 PM
94Z28LS1toLT1's Avatar
could be the opti
Old Apr 9, 2011 | 06:51 PM
SPEED750's Avatar
Can't be the opti. it wouldn't run without spark. I've seen a project lt1 not run because of water in the tank.
Old Apr 9, 2011 | 07:02 PM
red97rs's Avatar
Ok, so were would I start replacing stuff? Just all the fuel sending and ignition?
Old Apr 9, 2011 | 07:37 PM
Don't just replace parts without doing some troubleshooting. Check the fuel pressure.
Old Apr 9, 2011 | 07:55 PM
my1994z28's Avatar
Get a fuel pressure gauge and check the pressure with the key in the on position,and check it while cranking to start it.
Old Apr 9, 2011 | 08:05 PM
And scan if for codes.... unless you are so rich that you can just start throwing parts at it until you get lucky and hit the right one.
Old Apr 9, 2011 | 08:30 PM
red97rs's Avatar
No I'm not... If I were. Wouldnt be worrying about all this an I would just buy a z28 that was running.. And from what I have told you, do you think it's worth 2000? Good interior and paint, but true mileage is unknown
Old Apr 9, 2011 | 08:36 PM
hsyr's Avatar
I personally wouldn't buy it if there was starter fluid ran through it.
Old Apr 9, 2011 | 09:12 PM
red97rs's Avatar
Well if I bought it I could rebuild it.... Is it bad for it??
Old Apr 10, 2011 | 05:44 AM
bw_hunter's Avatar
Hmmm, why do you say this?
Old Apr 10, 2011 | 08:24 AM
pizzi-man's Avatar
I would check for spark first. You need a strong bright spark from the plug. Just because it runs on starting fluid doesn't mean it will run on gas. A weak spark is considered a no spark. Check the plugs and see how they look. If they are gas soaked then you know fuel is not the problem.
Old Apr 10, 2011 | 08:53 AM
red97rs's Avatar
Ok, so what's the worst case scenario?
Old Apr 10, 2011 | 09:02 AM
You don't need to be worrying about that, now. Troubleshoot and find out what is wrong. The whole picture will become clearer.
