wont start after rain!
Old Aug 19, 2007 | 05:26 PM
camarospeedracer's Avatar
So within the past month I have noticed after a lot of rain that my car wont start. It has now been 2 days straight that it has rained and my car will crank over and sputter if I give it gas, but still will not start. Sometimes it will pop and just run like crap and then die shortly after. I have absolutley no problems in dry weather so I know the rain has something to do with it... any ideas? I have work tomorrow and its going to be real fun trying to get there if I don't take care of this. Thanks!
Old Aug 19, 2007 | 05:46 PM
popstoy's Avatar
are you getting any water leaking onto your intake valley. if you have aleak through your cowl area water will build up in the valley between your valve covers and leak into any poor sealed areas of your intake giving you water in your cylinders.open your hood after rain and check for puddling.
Old Aug 19, 2007 | 07:07 PM
Severous01's Avatar
check your plug wires on a dry day....spray with a water bottle and see what happens
Old Aug 19, 2007 | 08:40 PM
MaximumJavelin's Avatar
Mine did the exact same thing. Turned out to be my ignition coil. Try putting a drop light right next to the coil and wait 30 minutes before starting it.
Old Aug 25, 2007 | 03:55 PM
Thomash's Avatar
When this happened to me I replaced the coil wire and it has been fine ever since. The dealer wanted to replace both the opti and the coil wire. That was ten years ago.
Brake_L8
Jan 20, 2015 09:44 AM
stavos
Aug 14, 2002 05:19 PM
wytblur
Aug 5, 2002 02:10 PM
wytblur
Aug 5, 2002 02:03 PM
Viper
Jul 30, 2002 02:06 AM
