wont start after Heads and cam
Old Oct 24, 2003 | 08:11 PM
  #16
BeaversTA's Avatar
I tried dropping the belt and that didn't help any thing. I will try and remove it tomorrow and see if that makes a difference. I think I will also try and re adjust the lash.
Old Oct 25, 2003 | 04:21 PM
  #17
BeaversTA's Avatar
Well guys I tried pulling the alternator and I re-adjusted the lash and it would not start. I tried giving it gas again and it starts up and runs pretty smoothly. But it still will not idle.
I guess I will pull the opti tomorrow and see how it looks.
Later
Old Oct 26, 2003 | 01:37 PM
  #18
Van5150's Avatar
Is the idel screw on the Throttle Body adjusted corectly ? That affects where your car idles.
Old Oct 26, 2003 | 05:29 PM
  #19
BeaversTA's Avatar
No the idle screw has not been ajusted. From reading here I was under the inpresstion that I should not mess with it. Is this not true.
Old Nov 9, 2003 | 01:13 PM
  #20
BeaversTA's Avatar
I found the problem it was a bad IAC. The car idles great now.
Thanks for all yalls help guys...
later
Old Nov 9, 2003 | 02:54 PM
  #21
bunker's Avatar
check for codes? maybe the opti harness or the connection check that or scan the car for codes.
InfernalVortex
Jan 17, 2015 09:35 AM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
