Wont start after a hard rain.
Old Jul 11, 2005 | 12:23 AM
ToocoolZ28's Avatar
My 95 Z28 wont start after a hard rain, just cranks and cranks but wont fire at all until it drys out. I replaced the coil the last time it did this but it didnt fix it. It runs great any other time with no problems. I replaced the opti about 130,000 miles ago, now the car has 220,000 miles on it.
Any ideas?
Old Jul 11, 2005 | 12:35 AM
eeg3's Avatar
Re: Wont start after a hard rain.
I had this problem with my old z28, and wires were just getting wet... unfortunately, I sold it before I ever got it fixed, since it didn't rain hard very often.
Try looking for any exposed wires that could be getting rained on, and covering them/replacing them. Water might be getting into the distributor, as well.
Old Jul 11, 2005 | 02:08 AM
fredmr39's Avatar
replaced the opti 130k ago.....wow, how long ago was that in units of time? I don't have much info to offer, just as everyone else will say - check for any exposed wires, play around with it, avoid all puddles (potholes are tricky), etc. etc...
Old Jul 11, 2005 | 08:44 AM
slimdawson's Avatar
Is your air filter getting wet somehow? I had a 4th gen cai on mine but when I first put it on, it was exposed to rain. The vented opti would suck in a bit of moisture and then cut off. A couple days later and it would be fine.
I am guessing you are getting water in the opti just like I was, although maybe a different way.
Old Jul 11, 2005 | 12:14 PM
ToocoolZ28's Avatar
The air filter is a K&N hanging below the front bumper, But I dont even have to drive it to do this. It can be sitting in the driveway when it starts to rain and if it rains enough it wont start.
I replaced the opti about 6 years ago, I also put new plug wires on at that time. New spark plugs and coil a couple of months ago.
Ron
Old Jul 11, 2005 | 01:09 PM
Brian Sutherland's Avatar
My Z did the same thing going threw car washes it was the ignition coil and wire after replacing both no problems
Brian
Old Jul 11, 2005 | 05:19 PM
slimdawson's Avatar
I am guessing that the high humidity finds itself inside the opti and is causing your problems.
Old Jul 11, 2005 | 05:29 PM
93transam1234's Avatar
ihad this problem with my caprice, it turned out to be one of the wires on the harness going to the coil. Next time it wont start get a friend to shake all the wires around and see if u can get it to fire...
Old Jul 13, 2005 | 02:39 PM
Mtrhds94Z's Avatar
Well the stupid fake scoops are inserts that often leak water onto the engine.. that could be causing a problem..
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
