Won't start after bad waterpump went out.
Old Oct 9, 2006 | 09:24 PM
All_Z_Way's Avatar
I have a 93Z that is a race car, so I have limited wiring, but I have a Baker vats bypass.
It won't start, but cranks fine. Occassionally it will try to hit, but never completely fires.
Fuel pressure is 40 and I do hear the fuel pump prime.
Seems to have good spark at plugs and coil.
Injectors have 12volts and pulse to roughly 8volts while cranking.
The car had ran fine until the waterpump broke bad and poored water out the bottom of the pump.
I changed the pump and now it won't start. The only wire I even touched was the coil wire.
The car acts as if the timing is off. It sort of drags and spits at times.
Opti-crap? Or other things I should check.?
Thanks,
James
Old Oct 9, 2006 | 09:26 PM
v8pwrdz28's Avatar
Re: Won't start after bad waterpump went out.
u have a 93 so it is the unvented opti, and since the water pump poured out onto the opti im sure it is toast.
Old Oct 9, 2006 | 09:29 PM
All_Z_Way's Avatar
It actually does have a 95 opti that is vented.
Old Oct 9, 2006 | 09:41 PM
OBE1 95Z28's Avatar
"Seems to have good spark at plugs and coil."
Buy a spark tester (about $10) and make sure the spark to the plugs can jump a gap of about 3/4". This will tell you if you have GOOD spark. If you don't it's likely the opti got wet. You might get lucky and the opti might dry out and work.
Old Oct 10, 2006 | 11:10 AM
All_Z_Way's Avatar
I also tried an different ICM & coil with no luck.
I guess it looks more and more like the Opti crapped out.
Old Oct 11, 2006 | 08:33 AM
All_Z_Way's Avatar
After the opti dried out, the car started and is running fine.
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
CobraEatr
Jul 24, 2004 11:37 AM
