Won't run above 4500rpm
When my motor revs to 4500 under full throttle in any gear, it starts popping and pouring black smoke. I guess that means the distributor is going bad. Unless someone has had this scenario before.
Re: Won't run above 4500rpm
You can't. That's why I said make sure it is above 40 psi because if its below that, you have a problem. I guess I overlooked the black smoke part of your original post
That makes me lean more towards an ignition system problem. I'd take a good look at your opti.
