wont idle after motor swap
Old May 30, 2006 | 06:07 PM
TransAmGT94's Avatar
i am pretty sure it is spark related. guessing the worst.(opti) it had only about 10k on it when i decided to pull the motor and i tried to reuse it. the car actually will idle when it wants to. it even backfires from time to time. checked wires made sure i put them on corectly. im going to double check them before i buy a new opti. any other suggestions?
i ready to get this beast up and running.
Thanks for any help you can give
chris
Old May 30, 2006 | 10:36 PM
OBE1 95Z28's Avatar
Re: wont idle after motor swap
If the opti was fine before the engine swap, it's probably fine. Double check all your connections, check for vacuum leaks, scan the PCM for unusual readings (i.e. water temp, IAT, IAC, O2 readings, etc).
Old May 31, 2006 | 01:57 AM
another thing i forgot to mention is after taking it around the block i will shut it off if. When i start it again it pours out white smoke. i was having trouble with the crossover tube but i think i got that fixed. Im going to check and see what codes im throwing.
thanks chris
Old May 31, 2006 | 07:10 PM
OBE1 95Z28's Avatar
White smoke is caused by coolant in the exhaust system. It could be residual coolant that fell into the exhaust when you drained your block or a bad head gasket. Always check the simple stuff first.
Old May 31, 2006 | 11:22 PM
im really thinking that that is left over from when i blew up the last motor and it just dried in their and it is just taking time to burn out
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
transam_388
Mar 15, 2015 11:53 AM
edman
Jan 25, 2015 02:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
