Wonder what was done to my LT1????
Old Feb 1, 2009 | 07:07 PM
19~Camaro~90's Avatar
Hey guy i bought a LT1 out of a 96 impala ss. It has a cold air intake that came with it that cost 350 bucks i looked it up! I start takeing some of the stuff off that i didnt need or want. Well what i found was new gaskets on the water pump then the timing cover? and also the oil pan? Do you think it was rebuilt? Cam swap mabey? Rebuilt? Give me ur guess!!!
thanks
kevin
Old Feb 1, 2009 | 07:20 PM
RamAir95TA's Avatar
There's no way to really tell unless you take it completely apart, but by just listening to the exhaust should be able to tell you if it has any valvetrain work done.
Old Feb 1, 2009 | 07:22 PM
Man dude i never heard it run got it from a junk yard complete and they said it sounded really good with the stock exsahust? idk i shouldnt get my hopes up i guess lol.
kevin
Old Feb 1, 2009 | 07:26 PM
RamAir95TA's Avatar
Yeah man, just be patient. Chances are if you only paid $350 for it there won't be too many surprises.
Old Feb 1, 2009 | 07:28 PM
No i bought it off these idiots lol the cold air intake "new" cost 350 buck i bought the complete engine for 500 buck with a 30 day warrenty.
kevin
Old Feb 1, 2009 | 07:30 PM
sn8ke eatr's Avatar
link to $350 cai please
what is it made out of carbon fiber or something?
Old Feb 1, 2009 | 07:39 PM
No its 3 1/2 in induction very heavy!!
http://www.azspeed-marine.com/19imcoairink.html
kevin
Old Feb 1, 2009 | 08:16 PM
96capricemgr's Avatar
WOW, honestly if the car belonged to someone stupid enough to pay $350 for that you better hope they didn't do anything inside the engine, because chances are the decisions would be just as poor.
There are some good intakes that cost a LOT but that basic setup can be duplicated for like $60 including the K&N filter. $10 if you keep the stock airbox and paper filter just delete the baffles and drill a few holes.
For the same price they could have had. http://www.impalaperformance.com/products.php
plumbing length is a restriction so shorter is better.
Still too much for a CAI, I bought one much cheaper USED
Old Feb 1, 2009 | 08:22 PM
Well hopefully it was rebuilt with the best of the best lol! Ya that is alot of money for that! Thats y i was like 500 for the hole engine and everything it was a good deal.
kevin
Old Feb 1, 2009 | 09:43 PM
Yeah I was not saying you got a bad deal.
Just have to understand many more cars are put together adly than done well. Honestly a lot of times the "money is no object" approach results in worse builds than guys who value a dollar a little more too. Reputation and marketting are not what makes good parts they are what make for big sales volume, not th same as results.
Old Feb 2, 2009 | 08:25 AM
DAVE00's Avatar
Have you taken the oil pan off? If so did you look at the crank/rods/main caps, as you can easily see if these parts are new or aftermarket if you have h-beam rods, arp rod bolts, converted to 4bolt main caps, pistons (they will have the brand stamped on the inside and will be visible from underneath. This is about all you can tell as there is really no way of knowing without tearing her down.
Old Feb 2, 2009 | 10:23 AM
a walker's Avatar
If you have a dial indicator with a magnetic base, you could try to figure out the lift on the cam and compare it to stock.
Old Feb 3, 2009 | 11:40 AM
ibanez6rg's Avatar
It's a good possibility that the gaskets have just been replaced.
Old Feb 3, 2009 | 12:22 PM
Ya i know lol i took off the valve cover and everything seemed stock idk? Mabey new gaskets to atleast they looked real good.
kevin
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
