Wiring up a shift light?
Old Jun 5, 2004 | 01:37 PM
F(ast)-body's Avatar
any sites on easy install info on how to wire up a shift light I can get my hands on?
Old Jun 5, 2004 | 02:10 PM
A couple of places you can get the tach signal on your 1995:
Red PCM connector "A", pin 13 (white wire)
White/black wire on the coil connector
Sorry, don't have a link for an install site.
Old Jun 5, 2004 | 02:35 PM
IrocSS85's Avatar
http://www.harlan-engineering.com/store/store.html
there is a link on there to an install page also. his shiftlights are great. no modules needed and small/bright. thats where Im getting mine from. he has other electonic stuff too.
chris
Old Jun 5, 2004 | 02:46 PM
chris
...except the install page does not work...
Old Jun 5, 2004 | 04:43 PM
IrocSS85's Avatar
yeah, your right. havent looked at it in a long time. but the link for install/instructions does work. you need adobe to read it though.
Old Jun 5, 2004 | 06:04 PM
12SCNDZ's Avatar
I spliced mine into the wire in my dash that goes to the factory tach. Works great that way.
Frank
Old Jun 5, 2004 | 06:08 PM
Yeah, I am right it doesn't work, but it does work? I don't understand.
I get "The page cannot be displayed" when I try to go there. I have no problem with Acrobat files.
Let's see a link that works.
Old Jun 5, 2004 | 07:30 PM
IrocSS85's Avatar
http://www.harlan-engineering.com/st...structions.pdf
if you click on shiftlight at the left top of the mainpage, then at the top right, under the red link titled "check them out" or just click on the link above. then scroll down to page 3 and there they are. writen instructions. but it doesnt specify on an LT1 eng. wich wire exactly you need. only that specific for the LS1.
Old Jun 5, 2004 | 07:39 PM
Ok, I was going to the Install University link that was on the bottom-it does not work. I looked at the one you mention, but as you say, it has no info for the LT1.
squarehead
Jan 15, 2015 07:02 PM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
