Wiring the switch for an E-Cutout?
Old Aug 16, 2005 | 05:28 PM
flatlander757's Avatar
I am ordering an e-cutout some time in the next day or so, but need to know how hard it is to wire myself? I know how to solder and whatnot, but where exactly do you run the wires to get to the ashtray area? I'd like to take out the cigarette lighter and mount the switch there, or in the ashtray. Any pics would help!
Also, what do you need to splice into to wire the cutout in?
Old Aug 16, 2005 | 08:58 PM
FastZ8's Avatar
Re: Wiring the switch for an E-Cutout?
remove your centre console (4 bolts, 10mm) and then run the wires from the bottom of the car through the rubber shifter boot( cut a pin size hole in it) and then i ran my power to my cigarette lighter and drilled a new hole underneath the lighter and stuck the toggle in there.
Old Aug 16, 2005 | 09:40 PM
Thanks, but aren't there a bunch of little wires hanging under the chassis then Ziptie them to something maybe???
Old Aug 16, 2005 | 09:43 PM
FastZ8's Avatar
there is only one big wire coming from the e-cutout itself. just zip tie it away from the exhaust and you'll be fine
Heathen1
Jan 2, 2016 04:27 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
