Wiring phantom a/f gauge ?s
Old Feb 1, 2004 | 01:30 PM
Supermanx500's Avatar
I have the phantom from autometer and I am not sure which wire is the o2 sensor wire that is coming out the pcm. Does anyone know which one it is and what color and out of which harnest. Any one that has it please give me a hand.
Old Feb 1, 2004 | 02:48 PM
MattysTA's Avatar
there are two depending on which one oyu want to run off of. they are on the same connector. one is blue the other is blue with a white stripe.
Old Feb 1, 2004 | 02:54 PM
Hawk's Avatar
like stated, you can run them off any of the precat o2's. As far as which wire is the signal wire, i wouldn't go blindly in the harness and "think" you know the right wire. Go check out the wiring diagrams(in the chiltons or haynes) they have the color of the wires in there. Also, you might want to check into splicing it in from the PCM side, might be easier. I have mine spliced into the driver side 02. If you splice it on the 02 side, DO NOT splice it in between the connector and the O2, splice it on the other side of the connector. The wires from the o2 sensor to the harness are shielded.
Brian
Old Feb 1, 2004 | 03:01 PM
thanks guy I will do that
Old Feb 1, 2004 | 03:36 PM
MattysTA's Avatar
Brian
hey mr technical, i see you got the car dyned on the spray huh? not bad. when you gonna get some new times maybe over this summer? i think maybe well have to make a few passes this year whatta say? you still gonna sell the car and get a viper? i always wanted to beat one of those ttyl.........
Old Feb 1, 2004 | 05:07 PM
Hawk's Avatar
I was offered 8500 for the car but couldn't let it go, you know how it is. And the viper plan is pushed back a little, I still have to pay off my truck but I'm thinking maybe 2 years now, haha. Oh well I atleast started a viper GTS savings fund, $500 a paycheck. Hmm, that will take me like, I don't know, a long while until I have some capital built up, I atleast want 20G down on the thing..............
When/If I get a GTS, i'll be sure to let you run it, . Atleast it will look good losing...............
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
