Wiring Issue Question
Old Nov 25, 2004 | 07:14 PM
Dfetter84's Avatar
Can anyone with an LT1 tell me where the pcm ground is.....doing a V6>v8 swap and I only have one wht/black 18AWG wire goint to a ground right above the battery into the block..Is there another one??? if so what color is the wire and where can I ground it to??
Old Nov 26, 2004 | 09:24 AM
Re: Wiring Issue Question
I guess you mean above the starter (not battery). Besides the grounds to the coil stud, there are no other grounds on the engine harness that hook up with a wire lug.
Old Nov 28, 2004 | 09:41 PM
Dfetter84's Avatar
See my problem is that I have 4 injectors not getting power to them to fire (1 7 4 6) I really have no clue on how to fix
Old Nov 28, 2004 | 11:00 PM
You are not providing enough info on the swap. Give the year of the car and what you are swapping into it. Sounds like you have a blown injector fuse or don't have the proper wiring to provide power to those injectors. 1 7 4 6 are all on one fuse (circuit).
Old Nov 29, 2004 | 03:29 PM
Dfetter84's Avatar
The car is a 95 V6 Auto swapped to an LT1 T56 of the same year or so I was told. already checked both fuses and I have swapped PCM's so the problem is not in the computer. If you know anyone that need a 95 PCM for LT1 M^ let me know
Old Nov 29, 2004 | 07:03 PM
If you have power at the fuse and not at the injectors, you need to check in between. schematic Check for voltage at "B" on the 8 cavity flat connector (C105 pic for reference) on the RH shock tower.
Old Nov 29, 2004 | 08:38 PM
Dfetter84's Avatar
We figured out that that pin doesnt have power... this is because my 95 V6 doesnt have any plug at all for the C105 connector to plug into. Do I need to get a body harness form a 95 Camaro and does it have to be V8? Or should I just run power to the pins that need it
O2s get power from F on C100, Inj from B C105 etc
Old Nov 29, 2004 | 09:26 PM
That's a common problem with conversions. When you said the injector fuses were ok, I assumed you had the fuse block and wiring from the LT1 car. All you need to do is find a way to provide switched power for that injector feed and you should be good to go.
Old Nov 29, 2004 | 10:42 PM
Dfetter84's Avatar
Should I just replace the harness in the front. If so do you know where I can get one. If i need to do this is there anything else I would need to replace. And if I do need to replace it do you know where I can find instructions on how to get the job done quickly
Old Nov 29, 2004 | 11:18 PM
It's up to you what you want to do. Salvage yard and factory service manual. Those things will be of the most value.
Old Nov 29, 2004 | 11:30 PM
Dfetter84's Avatar
Well I'm working on a lmited budget, I was just wondering if you knew much about it and how much would i need to take out to get to it, plus if it links with anything around the drivers side
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
lbrowne
Nov 13, 2011 04:25 PM
