Wiring issue for 93 to 94 engine harness
Old Jul 30, 2011 | 09:34 PM
undecidedfbody's Avatar
Hey guys
I am working on a 93 to 94 engine harness conversion
The car is a 93 z28 m6
It's a 96 motor out of a t/a with 93 intake manifold,93 ecu and harness
Is there any difference between 93 and 94 harnesses
Old Jul 30, 2011 | 10:06 PM
Re: Wiring issue for 93 to 94 engine harness
To answer your direct question, 93 and 94 harnesses are completely different and do not interchange. Now, if you want to use a 93 ECM and harness on a 96 engine, you can do that if you want. It just depends on what of the 96 you want to be able to use.
Old Jul 31, 2011 | 01:53 AM
I am going to use the 96 motor,93 intake,and 94 (ecu,harness). Do you have anything detailed about this. I'm a little in the dark on this situation
Old Jul 31, 2011 | 12:15 PM
What year/body car is it going in? There are details of some of the engine harness connections/differences on my website.
http://shbox.com/1/harness_connector_faces.htm
Old Jul 31, 2011 | 12:17 PM
Guest47904's Avatar
Guest
Why the 93 intake? You will have to change the injectors.
Old Jul 31, 2011 | 12:23 PM
A fellow member bought this from a friend with it done already
I just want to put a 94 harness on a 93 z28 any difference
It has a 96 block and heads only
Old Jul 31, 2011 | 04:30 PM
Guest47904's Avatar
Guest
The 96 has a crank sensor that you won't be able to hook up.
Old Jul 31, 2011 | 05:34 PM
They used the 93 harness with no problems
willismoons
Feb 14, 2015 08:42 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
siguy
Nov 27, 2014 10:07 AM
