wiring harness splicing question
Old Aug 17, 2004 | 10:45 PM
lt4 fd's Avatar
The wiring coming off one of the injectors, about an inch from the clip, is chewed up and I was curious if I can splice it with any wiring the same size or what I have to do? Same thing with the MAF sensor wiring except these are cut, can I just buy a pigtail and splice it in?
Old Aug 18, 2004 | 12:02 AM
kevmor99's Avatar
Re: wiring harness splicing question
As long as the plugs are good, I'd splice in some wire. It'd be best to solder and heat shrink, or use good crimp connections.
Old Aug 18, 2004 | 08:45 PM
lt4 fd's Avatar
Thanks a bunch dude! Im gonna go ahead and double check on this one since when installing longtubes to extend the o2 sensors reach it was made a point NOT to splice wire directly after the o2 sensor but into the wiring harness after the o2 sensor and its pigtail... Just double checking. Anyone?
Old Aug 18, 2004 | 08:59 PM
No problems I know of to splice on the injector harness.
Old Aug 18, 2004 | 09:27 PM
lt4 fd's Avatar
Thanks guys Ill get to it!
Old Aug 19, 2004 | 07:15 PM
kevmor99's Avatar
Maybe they're saying not to make the splice right after the plug? To leave a little? That'd be best (I hate when people cut wires right next to something, makes it hard to work with), but if it's bad there go for it. I extended almost all of the PCM wires about 4 ft. to relocate it
cmdeshon
Jan 4, 2015 11:15 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
$hawn
Aug 3, 2002 04:59 AM
CobraEatr
Jul 23, 2002 06:32 PM
