Question About Crate Motor In 94 Camaro????
Old Aug 19, 2004 | 07:11 PM
detroit1994z28's Avatar
I was wondering if those crate motors like the 509 big block merlin or zz502 or z454 will fit in a 94 camaro z28. I wanted to put a big block or a really nice crate motor in my car next summer. I wanted to know if it will fit or is there major modifcations to make for room. Anybody put a crate motor in there 93-97 camaro/firebird????
Old Aug 19, 2004 | 07:22 PM
Mindgame's Avatar
Re: Question About Crate Motor In 94 Camaro????
Yep, been done. Follow this link.
It's a tight fit. The air cleaner is going to get into the cowl area but you can see all that in the pics. The large small-block crate engines (427+) will fit just the same, minus a bit of weight.
-Mindgame
Old Aug 19, 2004 | 07:23 PM
TQdrivenws6's Avatar
will it fit? Yes.
will it be easy? No.
How much will it cost? A lot!
It had gotten alot easier now that BMR has the K-frame with the big block mounts, but its a little more than buying a crate engine, swaping the k member and dropping it in. There have been many posts about this in advanced tech, I suggest you do a search.
Old Aug 19, 2004 | 07:29 PM
Mindgame's Avatar
Yep yep.. the website I linked is pretty detailed on the swap. I second the search through advanced tech.... good info there as well.
-Mindgame
hotrodyou1
Dec 20, 2014 10:05 PM
ModdedNerd
Dec 18, 2014 10:52 PM
nballisru
Dec 14, 2014 05:01 PM
ChrisFrez
Dec 7, 2014 11:32 AM
ChrisFrez
Nov 23, 2014 10:33 AM
