Window rattle, what should I look for?
Old Jan 5, 2004 | 03:37 PM
rlax31's Avatar
My driver's window is loose (when the door is open you can see a gap between the weather stripping and door) and it rattles when the door is closed with the window not all the way up.
What should I look for/what do i need to tighten to get my window nice and tight?
Also the same door is sagging a little bit, should I just check and tighten the brackets that connect it to the car?
Is there anything else I should check that commonly comes loose in there over time?
Old Jan 5, 2004 | 03:41 PM
BLUE95ZZ's Avatar
I had a very simular problem if you remove the inner door panel there should be, I think two L shaped peices of metal with felt on them. with the window up you can adjust them to apply pressure to the glass. they loosen up over time or were never installed rite from gm
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
