Window Rattle
Old Apr 2, 2003 | 06:58 PM
Koby's Avatar
Window Rattle
My windows rattle like crazy when the are half way down. I figured out that the track that the window goes up and down on is partly the problem. The connection between the track and the window isn't very tight, and it rocks back forth causing a rattle. Is there anyway to tighten this up, or is this just normal? The rattle is really bad, it sounds like the window is going to fall off. Any advice is appreciated.
Thanks.
Old Apr 4, 2003 | 12:28 AM
fbird95's Avatar
Thats how GM's windows get over time, especially their windows that have no frame. I think they have a rebuild kit but its not worth the time or effort. I have a slight rattle in my car now. I believe that it stems from leaving the windows have way down and hitting all those bumps, lossens the clips on the bottom of the window.. One day in my 88' caprice the window was rattling and it just feel into the door.
Old Apr 4, 2003 | 12:32 AM
pennys58's Avatar
I am having the same problem with my windows. I just replaced the window motors and they are still slow as HE!!...I dont know what else to do to make them faster. I am gonna get some new switches I guess. But, everything rattles on the camaro...it gets annoying over time.
Old Apr 4, 2003 | 08:08 AM
Most often, it is the stabilizers that need to be replaced or adjusted. These are the same items that can cause scratches on the inside of the windows. Adjustment procedures can be found here.
Old Apr 4, 2003 | 08:21 AM
93transam1234's Avatar
fast windows
To make ur windows move up and down faster spray the inside of (brain fart) ruber thing around the frame of the door that the window goes in with WD-40. you know what i am mean
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
