Windage Tray Clearance - 383 4 bolt
Old May 10, 2011 | 02:11 PM
aaron_depue's Avatar
I am trying to get my OE windage tray to work with my new 383 4bolt block. I have done a few searches and found the part numbers for the 3 main cap studs from Milodon but.....
My question is :
What about the back stud that mounts to the oil pump? Does this also need to be modified?
Old May 17, 2011 | 05:27 PM
Re: Windage Tray Clearance - 383 4 bolt
Can I just use the original stud and some washers? Any insight here fellas?
Old May 17, 2011 | 09:57 PM
Kevin Blown 95 TA's Avatar
I used a different tray, but I just bolted it down back there. As long as it doesn't hit the crank and you have about 1/8" clearance. As you can see, i probably could have used a longer stud, but I just Locktited it on there and it's been there ever since.
Old May 18, 2011 | 08:51 PM
I was just making sure there was not another stud i needed to get from Summit. Im using my OE windage tray from my 94 Z.
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
maybe2fast
Mar 16, 2015 09:45 AM
97 RedSS
Jun 10, 2003 07:58 PM
