Windage tray with 3.75" stroke crank?
Old Jul 8, 2003 | 09:00 PM
thewinner's Avatar
Is it possible to run a windage tray with a 3.75 stroke crank? I have the arp main studs with the windage tray attachment thingy, and the crank comes all the way up to the very top of the stud.
so i dont think i can run one? how about crank scrapers? do those work similar to the windage tray? same idea?
Old Jul 8, 2003 | 09:07 PM
96z's Avatar
96z
I have both. Its doable.
Old Jul 8, 2003 | 09:39 PM
thewinner's Avatar
you dont happen to have any pics do you? cause the crank comes all the way up to the top of the stud
by both you mean windage tray and scraper? i thought having both those were counteractive cause the scraper will drop oil on the tray where the crank can pic kit up again?
Old Jul 8, 2003 | 09:54 PM
96z's Avatar
96z
Click the Z link in my sig and go to the photo page. Those should show you what you need.
Old Jul 8, 2003 | 10:04 PM
thewinner's Avatar
what kinda tray is that? part number would be killer! and do you have the arp main studs? is it one of the milodon 80 dollars ones?
does the crank scraper just sit on the pan rail and get held down by the oil pan studs/bolts?
are you running stock oil pan? looks like you are!
Old Jul 8, 2003 | 10:15 PM
Andrew Coats's Avatar
I just built a new motor with a 3.75 stroke just like 96z has. I used the same tray but have modified it some. The tray had been clearanced on the sides of it so that the rods will not hit the tray. It turned out great. I am selling my because I decided to go with a canton oil pan. The tray was never used and i'm selling it. Let me know if you are interested.
Old Jul 8, 2003 | 10:23 PM
thewinner's Avatar
How much are you looking for? any pics?
what kind is it btw
Let me know!
Old Jul 8, 2003 | 10:40 PM
I sent you mail.
Old Jul 8, 2003 | 10:49 PM
InjectedSS's Avatar
dude its a PITA this SAME EXACT thing happened to me! you cant put the tray back in the stock location like it was when the motor was stock! you know what i mean how the very back of the tray hole goes above the oil pump! we tried that and like you the studs werent long enough! so we were going to try to move the tray FORWARD ONE CAP basically you would have the 3 MAIN CAPS RIGHT! well on the last cap the one closest to the oil pump you would put ONE windage tray stud, then on the middle cap you would have NONE then on the second one from the front you would have the TWO OTHER windage tray studs! but the tray sat too close to the rods so this didnt work for me either! i actually ended up NOT running the tray and i havent had
Old Jul 8, 2003 | 11:01 PM
thewinner's Avatar
sent you mail andrew
Old Jul 9, 2003 | 01:26 PM
TimChiaretto's Avatar
Andrew,
If you haven't sold the windage tray yet let me know, I will buy it. If you have sold it please let me know who made it, part number would be great too.
Old Jul 9, 2003 | 01:37 PM
thewinner's Avatar
Thats mine sucka!
Old Jul 9, 2003 | 02:51 PM
thewinner,
No problem, just want to be next in line in case you don't buy it!
Old Dec 4, 2004 | 02:54 PM
Highlander's Avatar
Re: Windage tray with 3.75" stroke crank?
Any info on that windage tray?
smoknta
Aug 27, 2015 05:07 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
Catmaigne
Jul 14, 2015 05:17 PM
