Will This Work To Diagnose Opti
Old Oct 29, 2009 | 08:02 PM
snorkelface's Avatar
Question Will This Work To Diagnose Opti
So I'm trying to figure out why the car won't fire up. I'm getting fuel pressure and have already tried bypassing my MSD BTM and of course checked the fuses.
Now, I want to go through the system and determine what the problem is before I just start replacing parts. I was going to go through the steps posted here: http://www.cz28.com/forums/showthread.php?t=601565
I found this mulitmeter online: http://cgi.ebay.com/ebaymotors/Elect...motiveQ5fTools
Will this do what I need to do to perform the diagnostics? I need to get this thing running!
Old Oct 29, 2009 | 09:22 PM
MikeGyver's Avatar
Any multimeter will work. Go to harbor freight and get yourself their $3 special.
An LED would probably also work as you're just checking for a (probably 5v) pulse each time a cylinder should fire.
Old Oct 29, 2009 | 09:29 PM
Originally Posted by MikeGyver
Any multimeter will work. Go to harbor freight and get yourself their $3 special. An LED would probably also work.
I did see that one but wasn't sure if it would give me all the info I needed. Remember that this will be my first foray into electronic daignostics so I need to make sure the readings will be simple for me to understand. Are you referencing this one?:
http://www.harborfreight.com/cpi/cta...emnumber=46972
Old Oct 30, 2009 | 03:58 AM
MikeGyver's Avatar
Negatory, this one. http://www.harborfreight.com/cpi/cta...emnumber=98025
Old Oct 30, 2009 | 09:39 AM
Oh man, great find! Okay, don't mean to beat a dead horse, but is it at all likely that he additional 8 tests the more expensive multimeter will do will come in handy some day?
Thanks for the link!
Old Oct 30, 2009 | 09:47 AM
Z28SORR's Avatar
No. 99.999% of the test will be for Volts and Resistance/Continuity.
Old Oct 30, 2009 | 09:57 AM
97FormulaWS-6's Avatar
If you want to see if it's even firing, just pull a sparkplug wire off; throw a spare plug into the end of the wire, and set it onto the head or block or whatever and see if it fires when you crank it over. Easy, and doesn't cost anything.
Old Oct 30, 2009 | 01:19 PM
I'll give that a try. I have a spare new plug.
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
