Will This Work To Diagnose Opti
So I'm trying to figure out why the car won't fire up. I'm getting fuel pressure and have already tried bypassing my MSD BTM and of course checked the fuses.
Now, I want to go through the system and determine what the problem is before I just start replacing parts. I was going to go through the steps posted here: http://www.cz28.com/forums/showthread.php?t=601565
I found this mulitmeter online: http://cgi.ebay.com/ebaymotors/Elect...motiveQ5fTools
Will this do what I need to do to perform the diagnostics? I need to get this thing running!
Any multimeter will work. Go to harbor freight and get yourself their $3 special.
An LED would probably also work as you're just checking for a (probably 5v) pulse each time a cylinder should fire.
http://www.harborfreight.com/cpi/cta...emnumber=46972
Negatory, this one. http://www.harborfreight.com/cpi/cta...emnumber=98025
Thanks for the link!
If you want to see if it's even firing, just pull a sparkplug wire off; throw a spare plug into the end of the wire, and set it onto the head or block or whatever and see if it fires when you crank it over. Easy, and doesn't cost anything.
