Will this be too loud for everyday driving?
Old Jan 2, 2004 | 01:49 AM
  #16
revtime's Avatar
In my opinion quite a bit at idle, Wide Open Throttle is not much different though.
I have had several guys I have raced mention that the car sounds somewhat tame when they hear it start and idle but when we race and I open it up they are like DAMN that things loud.
Old Jan 2, 2004 | 01:52 AM
  #17
QCKZ28's Avatar
revtime
how long are the purple hornies?
i know that plays a role in quiet at idle.
but length dont help at WOT
jesse
Old Jan 2, 2004 | 02:01 AM
  #18
revtime's Avatar
I actually had to cut them down to fit the DD subframes I have on the car.
They came with about 6 inches of extra pipe after the muffler itself then a turndown, I had a local muffler shop weld in some O2 bungs and shorten the ends of the mufflers but keeping the turndowns.
I posted a pic on here not too long ago, do a search for purple hornies and you should find it.
Old Jan 2, 2004 | 02:12 AM
  #19
QCKZ28's Avatar
interesting, i have KB DD subframe connectors also. i wonder how much that will interfere with the 3" true duals im planning on?
jesse
Old Jan 2, 2004 | 02:25 AM
  #20
revtime's Avatar
It can be tough to clear the DDs but a good pipe bender should be able to handle it.
Clearance on the crossbrace is the problem, alot of guys who do true duals take out the wavy piece of metal in there to get clearance, I run a Granatelli Gload brace as well so they have to clear that too.
I have a pair of Lowbaks that I want to put on and run the pipe all the way back to the axles with turndowns, its a real trick to run a Gload brace and DDs with a X pipe or H pipe, I am just gonna go without a crossover pipe.
Old Jan 2, 2004 | 02:27 AM
  #21
QCKZ28's Avatar
my factory brace has been taken off, in favor of the lakewood driveshaft loop, it doubles as the cross brace
jesse
Old Jan 2, 2004 | 02:31 AM
  #22
revtime's Avatar
Thats cool I have been thinkin about the BMR one.
Make sure you check around and find a good exhaust man and he should be able to fix you up on the true duals.
Try and see some of his other work to make sure, I have seen some hack jobs on true duals and these were supposed to be done by professionals.
Old Jan 2, 2004 | 02:36 AM
  #23
QCKZ28's Avatar
thanks for the advice
jesse
Old Jan 2, 2004 | 03:33 AM
  #24
Robert95z's Avatar
I always wanted to drop an LT1 in an s10.... but my camaro is a project as it is.. cant afford two
Old Jan 2, 2004 | 04:10 AM
  #25
madhatter's Avatar
True dat. My car is a perfect example.
Old Jan 2, 2004 | 12:49 PM
  #26
HellSpawn T/A's Avatar
There is no such thing as too loud for everyday driving You'll be fine with that setup.
Old Jan 2, 2004 | 08:13 PM
  #27
LT1s10ss's Avatar
Yeah, I agree with that. My girlfriend doesn't want it too loud to where we can't carry a conversation I don't mind though, it might keep her quiet for a while
Seriously, does anyone know if there's a big difference in how loud the bullets and welded ultraflos are? And if I go with the ultraflos, will the dual in/out muffler work the same as an H or X pipe?
Thanks!
Chris
Old Jan 2, 2004 | 08:51 PM
  #28
AxeGrinder30thZ's Avatar
I think you'll like it. I have SLP headers, no cats, 2.5" X pipe into 3" Bullets turndowned right before the axle. I knew the car would be loud, but you never know how loud your car is until you let someone else drive it. I let my friend drive it and I could hear the car from a LONG distance. The car does have a good bit of rattling now, and the interior resonance is high. But the sound and nastiness of the Bullets are worth it in my opinion. The cats will quiet them down a little bit but it will still be a loud setup. Overall, I think you'd love them.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
737drivr
Feb 20, 2015 11:54 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
squarehead
Nov 21, 2014 08:02 PM
