Will these work for me? Rockers
Old Jan 27, 2005 | 10:53 AM
southern78's Avatar
Comp Cams Magnum Rocker Arms
1.6 Ratio, 3/8'' 1987-Up Heads Self Aligning, 16/pkg
$191.99
Pretty much stock setup, stock cam. I would buy some LT4 springs to use with them. Do I need to get new push rods also while I am in there. I think I am going to grab these unless some one tells me its not worth the money.
Thanks,
I promise last post ragarding this issue.
Old Jan 27, 2005 | 11:06 AM
sssalah's Avatar
Re: Will these work for me? Rockers
These will work and its good that you're going with the lt4 springs to handle the little extra lift, and the pushrods are fine if thay check straight . I wouldn't have those, however, only for the reaon they're not full rollers.
Old Jan 27, 2005 | 11:10 AM
southern78's Avatar
So a full focker would be better? Or would I even notice with my setup? No plans on upgrading cam or anthing.
Old Jan 27, 2005 | 11:12 AM
Jameslt1TA's Avatar
Ya they will work fine... check out www.cmotorsports.com ... id get the new pushrods that they have and they're only like $25 i think
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
alphaauto
Jan 23, 2015 07:42 AM
Jazsun
Dec 29, 2014 12:14 PM
