Will these RR's fit my LT1?
Old Jul 29, 2004 | 10:58 AM
TransAmGT's Avatar
My heads are stock
We have a NEW set of Aluminum Roller Rockers for a SB Chevy.This set is 1.6 ratio with 7/16th's polylocks. These Cal Auto Tech 2024 T3511 extruded aluminum rocker arms are manufactured from the best aluminum alloy available in the automotive racing industry. State-of-the-art extrusion processes make the optimum flow of the aluminum grain for superior wear resistance. The NSK licensed fulcrum needle bearing reduces friction and increases durability. Heat treated roller tips to HRC60 provide superior resistance. All rocker arms come with polylocks.
These sell new for $240.00.
Also would this mean they are slef aligning or non-self aligning?? And what's the difference...will I tell a difference with stock heads?
Old Jul 29, 2004 | 12:19 PM
TransAmGT's Avatar
Re: Will these RR's fit my LT1?
Are stock LT1 studs 7/16 or 3/8 ? I guess that is what I need to know!
Old Jul 29, 2004 | 12:55 PM
Dave C. '97 Z28's Avatar
Stock LT-1 studs are 3/8".
Replacing the studs is realitively easy, but those rocker sound like the wide-body types since I don't believe you can get a narrow body with a 7/16" stud (I might be wrong), and the wide-body (or regular ones) won't fit under the valve covers without modifying the ribs in the valve covers to clear them.
-Dave C. '97 Z28
PS: I didn't see where they said self-aligning, so I would assume they are not. Most aftermarket rockers are not self-aligning.And if you want to run non-self-aligning rockers, you need to get guideplates and hardened pushrods.
Old Jul 29, 2004 | 01:02 PM
TransAmGT's Avatar
Here is a link to the ebay auction...let me know what you think!
They also have a set that are 3/8ths
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Jul 29, 2004 | 01:10 PM
Thanks! I just did the "Buy It Now" for $50!!
Just kidding.
Those are definitely the non-self-aligning type. They're also wide and you'll need cover clearancing, guide plates, and hardened pushrods for those.
Also, I don't see the little screw in locks that go in the center of the nuts.
-Dave C. '97 Z28
HectorM52
Jun 23, 2016 08:42 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
