Will these fit LT1 heads ???
Old Aug 28, 2006 | 12:53 AM
AZ2ENVY's Avatar
Will valve springs off of a 2002 LS1 car fit an LT1 head ? I was
just doing some comparing between comp cams beehives 26918-16
springs and stock LS1 springs , and I noticed they are pretty much the same
exact spring . So will the LS1 springs work on an LT1 head with a cam
around .600 lift ? If so will the 787-16 retainers fit the LS1 springs ?
I searched for a while and found nothing on this so maybe its a new
find
Comp Cams beehives 26918-16
http://cgi.ebay.com/COMP-CAMS-CHEVY-...QQcmdZViewItem
Stock LS1 springs
http://cgi.ebay.com/LS1-beehive-type...QQcmdZViewItem
Old Aug 28, 2006 | 01:05 AM
11secgen's Avatar
Re: Will these fit LT1 heads ???
yes but you need a special retainer.comp makes em. lemme know if you cant find the part number.
Old Aug 28, 2006 | 01:06 AM
11secgen's Avatar
Old Aug 28, 2006 | 01:12 AM
AZ2ENVY's Avatar
Is the part number for the retainers 787-16 ???
And any idea on the max lift stock LS1 springs can handle ??
Old Aug 28, 2006 | 01:37 PM
AZ2ENVY's Avatar
So will stock LS1 springs handle up to .600 lift on an LT1 head ? Thanks
Old Aug 28, 2006 | 06:01 PM
Severous01's Avatar
they'd better...my friend's camaro is a 355 blower motor with about that much lift and lsx springs. he's going to be pissed if it doesnt.....
Old Aug 28, 2006 | 06:09 PM
AZ2ENVY's Avatar
Are they stock LS1 springs ? Are they on an LT1 ?
Old Aug 28, 2006 | 09:20 PM
96flame's Avatar
Stock GM LS1 valvesprings are NOT good for .600" lift the comp 26918's are. The LS6 aren't even good for .600". Don't cheap out on one of the most important parts.
Old Aug 28, 2006 | 09:27 PM
AZ2ENVY's Avatar
Im not cheaping out on anything . I was just curious if they would work
or not cuz they seemed similar in some aspects
Old Aug 28, 2006 | 10:56 PM
97Formy's Avatar
I think he was directing that more twords Severous01 and at the same time letting you know that they won't handle a .600 lift.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
