Will a stock frinction disk work with a Spec Stage II PP and T/O?
Old Nov 21, 2004 | 01:41 PM
)2overt SS's Avatar
Just curious... I've been having problems with my Spec Stage II set up, and I'm kind of suspicious of the Kevlar disk that Spec using with the Stage II. I've read that it can be very tempermental.
So I was just wondering if the stock (or I suppose any non kevlar friction disk) will work with the Spec Stage II PP, T/O bearing and a machined stock flywheel.
Thanks!
Old Nov 21, 2004 | 05:21 PM
GreenDemon's Avatar
Re: Will a stock frinction disk work with a Spec Stage II PP and T/O?
Do you have the stock parts laying around? You should probably check the thickness of the clutch disk and t/o bearing to make sure you don't have any engagement/disengagement problems. For example, if the throwout bearing is too small the clutch will not disengage all the way, if too large your clutch won't last very long. Also, the PP might have more pressure than the stock one, so it still won't feel the same as stock.
Brandon Wittmer
Dec 20, 2014 09:51 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
97 RedSS
Jun 10, 2003 07:58 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
Burn_Out
Aug 18, 2002 08:49 AM
