Will this spring hold cc306 lift??
Old Jan 21, 2006 | 05:19 PM
BadCamaro's Avatar
Lightbulb Will this spring hold cc306 lift??
I found this kit in this site . will this ket be good for 306?
http://store.summitracing.com/defaul...5&autoview=sku
Old Jan 21, 2006 | 06:15 PM
96m6lt1's Avatar
Re: Will this spring hold cc306 lift??
i would not use any other spring than the 918 or 987 with that cam and also 10*locks and retainers.........
Old Jan 21, 2006 | 07:01 PM
30696bird's Avatar
I agree, I used the 918's
Old Jan 21, 2006 | 07:02 PM
xxsaint69x's Avatar
yes, that is the spring you need for a CC306. I used it on my car back in the day. No problems at all.
Marcin
Old Jan 21, 2006 | 07:31 PM
BadCamaro's Avatar
Question Re: Will this spring hold cc306 lift??
Marcin
Will it fit well in the stock head? Which pushrod should I need?
Which lift it can handle?
Old Jan 21, 2006 | 10:43 PM
Josh'95Z28conv's Avatar
Marcin
Will these work with the stock locaters?
Old Jan 21, 2006 | 10:48 PM
xxsaint69x's Avatar
everything you wil need is in that kit. I used it on my car without any problems (stock heads). As far as pushrods, if you have a 93-95 it came with hardned pushrods. If you do want to get some new ones i think they are like 30 bucks. I dont have a part number but look for cheap Comp Cams Magnut Pushrods 7.20 in lenght i believe.
Marcin
Old Jan 22, 2006 | 07:14 AM
BadCamaro's Avatar
any site for duble time chain?
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
