Will spraying starting fluid on MAF destroy it?
Old Mar 3, 2003 | 12:35 AM
Trans-Am's Avatar
Well my dumbass for got to connect my racetronix fuel pump conector. When I went to start the motor for the first time, I quickly figured out that it wasnt getting fuel after a quick shot of starting fluid, and lack of pump noise,lol!! So is it smoked?Because the car is having some issues idling rolling to a stop in nuetral. Other symptoms as well. thanks any info is appreciated~!!!!~~~~rob
Old Mar 3, 2003 | 03:30 AM
Racetronix's Avatar
Post
Ouch, that has to hurt
Check your MAF readings at idle and see if they are normal.
If this is a LT1 sometimes the HP pump will bump the fuel pressure a bit. Reset the computer and give it a chance to re-learn the BLMs. Hopefully your MAF is OK?
Racetronix
Old Mar 3, 2003 | 07:38 AM
It could also be that your computer has not yet learned a solid setting for idle if you had the computer disconnected. If that is the case the more you let it idle, the better it will become.
Klypto
Mar 23, 2016 09:05 AM
Fatdog2
Feb 13, 2015 08:19 PM
David Dorris
Jan 17, 2015 08:10 PM
tds1213
Nov 27, 2014 12:55 PM
