Will Sea Foam Kill O2's? (mixxed with gas)
Old Feb 12, 2006 | 06:11 PM
97BBlackZ's Avatar
hey guys,
I just got new 02's for my car and plugs(not installed yet). since the hold ones took a **** and im replacing the plugs as well.
But if i run the sea foam through my gas, mix it with my gas, will it kill my 02's that way? Or is it safe. I know if you do it any other way the smoke can kill the 02's and i would hate to have to go through ANOTHER set! These damn things arnt cheap haha.
Old Feb 12, 2006 | 06:29 PM
matt65's Avatar
Re: Will Sea Foam Kill O2's? (mixxed with gas)
I used it on my car. I have no rear 02's but do ahve front. No issues.
Old Feb 12, 2006 | 06:35 PM
SAR2K's Avatar
No issues with mine when I did it with straight sea foam.
Old Feb 12, 2006 | 06:51 PM
97BBlackZ's Avatar
aight thanks guys. I guess i'll go ahead and install them then instead of waiting to do it.
Anyone else not have any problems?
Old Feb 12, 2006 | 06:58 PM
aboatguy's Avatar
When I first bought my car, I ran seafoam through the vacuum line for the power brake booster IOT clean the top end. NO DRAMA
Old Feb 12, 2006 | 07:01 PM
DiabloGT's Avatar
wait why do you guys use sea foam?
Old Feb 12, 2006 | 07:09 PM
97BBlackZ's Avatar
Its known for cleaning the inside of your engine VERY well.
Hell last time i used it in my gas i picked up a few MPG. Prior to that it was running extremely rich for a long time.
Old Feb 12, 2006 | 08:49 PM
DiabloGT's Avatar
where do you buy it and how much do you put in when about how much gas do you have in the tank? oh ya and how much does it cost
Old Feb 12, 2006 | 09:23 PM
97BBlackZ's Avatar
Its not to much less then 10 for 2 maybe, its been awhile. The only place i found around here that had it was Oreillys auto parts.
As far as putting it in your gas. It just say to pour it in there and then fill up the tank, then just drive around.
Old Feb 12, 2006 | 09:28 PM
Cerwin Vega Fan's Avatar
One of the common mistakes people assume about seafoam is that just pouring it through your engine is the best way to use it. The best way is to pour it through something like the brake booster and then shut the engine off. Think about it, seafoam flashes really easy so it doesn't do a good job cleaning things like the pistons, it just burns off and goes out the tail pipe. With the engine off the seafoam can sit and eat away at the carbon that has built up.
Old Feb 12, 2006 | 09:30 PM
97BBlackZ's Avatar
Yes do a search on it. Also if you do plan to run it through the engine, through the other ways make sure you dont pour to much to fast. Hydrolock = bad
Old Feb 13, 2006 | 05:50 AM
cehan's Avatar
On the back of the can it says "O2 sensor safe".
Chris
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 10:09 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
