how to clearance valve covers?
Old Feb 13, 2006 | 01:34 AM
Cmr0z28's Avatar
So I cut out some of the metal baffles or whatever they are, with a dremel....but the valve covers still won't fit on with the Pro Magnums.
Is there any easy tool / trick to doing this?
Old Feb 13, 2006 | 02:11 AM
Joe B's Avatar
Re: how to clearance valve covers?
I also used a dremel tool (with a cutoff disk).......I trimmed everything close to "even" with the top of the inside of the valve cover......then the pro-mag's cleared no problem.......it does take a little time
Old Feb 13, 2006 | 05:33 AM
cehan's Avatar
Do a search on this. There are a couple of excellent "how-to" threads with pictures. I did mine using this information for my 1.6 Pro Mags. No cutting or grinding required, just bent the interfering valve cover internal bracing and breather baffle with pliers.
Chris
Old Feb 13, 2006 | 06:59 AM
lt1andy's Avatar
Check this out ---http://www.hotss.com/Members/scott_vaca/pro-mag.htm
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
thenewkid
Nov 29, 2014 04:54 PM
