Will a rear end with traction control work on my none traction control car?
Old Feb 10, 2004 | 09:36 AM
93transam1234's Avatar
Exclamation Will a rear end with traction control work on my none traction control car?
I am going to be buying a rear with 3:73 gears but the car it was in had traction control and my car doesnt will this be ok will i still have ABS?
Any good install pages for rear ends?
Old Feb 10, 2004 | 10:29 AM
carlos64030's Avatar
You can use it.
Old Feb 10, 2004 | 11:50 AM
jbird's Avatar
Yeah, you should be able to use it
Old Feb 10, 2004 | 12:36 PM
Red96Lt1's Avatar
Traction control uses the ABS sensors to sense wheel spin, it has nothing to do with the rear end.
Old Feb 10, 2004 | 01:34 PM
stik6shift93's Avatar
you can do it but you will loose abs
Old Feb 10, 2004 | 02:43 PM
Anyone else know if i will be able to keep my ABS or if i will lose it?
Can programing change anything about it
Old Feb 10, 2004 | 03:32 PM
The "ABS only" rear (yours) has a large single reluctor wheel, mounted on the differential carrier, and a sensor mounted on top of the diff housing. The TCS + ABS axle has a small, individual reluctor wheel mounted on the end of each axle and a sensor on the backing plate. Unless someone has found a way to interface the different pulse rates produced by the large diameter reluctor on the differential (ABS), and the small diameter reluctor on the axle (TCS + ABS), I'd say you're going to have a problem.
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jon657
Jul 19, 2002 07:51 PM
