Will my stock rods hold up?
Old Feb 6, 2011 | 08:42 PM
henryz28's Avatar
I am going to have my lt1 rebuilt soon. I am using these pistons http://www.summitracing.com/parts/TRW-8KL2256F30/ along with the stock rods and crank if they turn out to be good. My question is will the stock rods with ARP rod bolts be sufficient for these pistons running a lt4 hot cam and le1 heads?
Old Feb 6, 2011 | 11:20 PM
Bersaglieri's Avatar
Re: Will my stock rods hold up?
I don't see why not, but I wonder why you'd even change pistons from stock with a Hotcam + LE1 head setup? Stock components with ARP bolts should be able to handle the RPM and power you'll see with that setup. Assuming your on a budget and the bores/pistons aren't messed up, I'd go with a hone and re-ring...
-Dustin-
Old Feb 7, 2011 | 10:55 PM
henryz28's Avatar
-Dustin-
The bores were messed up; bad ring. A hone and re-ring would not work, so that's why I am going .030 over bore; I figured if it needed bored I might as well upgrade the pistons.
RUENUF
May 25, 2016 08:10 PM
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
