Will an LT4 starter bolt directly up to an LT1
Old Nov 16, 2005 | 05:53 PM
csmonte's Avatar
a starter for an LT4 corvette will it bolt up directly to an LT1 camaro. I can't see why it wouldn't but just checking.
thanks
Old Nov 16, 2005 | 06:20 PM
FastZinTennessee's Avatar
Re: Will an LT4 starter bolt directly up to an LT1
It will bolt right up, but will not clear some F-body headers. I have a pair of SLP 94-95 single cat style headers in the garage that I mocked up, and they did NOT clear the LT4 starter. My new Hooker LT's fit fine.
Refer to this thread for more info-
http://web.camaross.com/forums/showthread.php?t=409610
Old Nov 16, 2005 | 07:17 PM
chevy94c's Avatar
Yes it will. If you have headers might have to move it around to get it in there. I did with the SLP's.
Old Nov 16, 2005 | 07:33 PM
Maybe yours was different, my inner primary was hitting one of the long thru bolts on the starter that held the half together. I just went outside and mocked it up again just to be sure I wasn't talking out of my ***, and sure enough, it's hitting- barely, but hitting.
If I were inclined to make it fit, I'd probably just clearance that part of the primary with a hammer...... But I don't like doing stuff like it.
Old Nov 29, 2005 | 09:47 PM
csmonte's Avatar
anyone else give this a Try??? I'm trying to make sure somthing will fit, its a GM LT4 starter or an autoZone piece of junk.
thanks for any help
Old Nov 29, 2005 | 10:02 PM
fastcamz28's Avatar
Mine bolted right up w/o any problems. I run Hooker shorties...no clearance problems. To me, the results were worth it...very strong starter.
Old Nov 29, 2005 | 10:12 PM
DavesLT1's Avatar
What are the benefits for an LT4 starter? anyone bolt one up with Jet Hot LT's?
Old Nov 30, 2005 | 12:19 PM
csmonte's Avatar
I'm accually not sure of the advantage, I have a chance to buy one local, but I don't want to get stuck with it if it doesn't fit with my FLP long tubes.
Old Nov 30, 2005 | 12:29 PM
Chris 96 WS6's Avatar
Its lighter, that's the main benefit. Little bit higher tq too I think.
Old Nov 30, 2005 | 12:59 PM
JohnD's Avatar
One advantage is that you can buy the LT4 unit new. Std. starters are rebuilt like alternators.
Old Nov 30, 2005 | 01:28 PM
fast 93 z's Avatar
I have been using the LT4 starter for years now on mine with Hooker long tubes. Works great!!
Old Nov 30, 2005 | 01:55 PM
Grn4fbody's Avatar
Damn I thought they would be the same...I just replaced my LT1 starter i should had gotten an LT4
Old Nov 30, 2005 | 05:44 PM
jah1542's Avatar
Know the P/N by any chance?
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
