Will I pass emissions?
Old Feb 14, 2003 | 12:59 PM
Rocks94z28's Avatar
mods are in sig,
exhaust is
1 3/4 slp shorty's
random tech highflow cat.
flowmaster 80 series muffler,
on 93 octane gas, no air fittings crap hooked up,
this was programmed through pcmforless.com for all of the mods above,
light head work also,
Old Feb 14, 2003 | 01:38 PM
Z95m6's Avatar
I hope you can since i will be trying a 230/236. I think since you have a cat and tuning you will pass very easy. If they have a visual inspection you will fail with no air or egr on it.
Old Feb 14, 2003 | 02:06 PM
Rocks94z28's Avatar
thats cool,
hotcam is 218/228 so good luck with that,
-Jesse
Old Feb 15, 2003 | 01:36 PM
Rocks94z28's Avatar
ttt.......
Old Feb 15, 2003 | 01:48 PM
Jason Dove's Avatar
You should pass just fine, my cc305 got through with lots of room to spare... (after I replaced my defective Evap Canister).
Old Feb 15, 2003 | 01:59 PM
gb95zconv's Avatar
You should pass the sniffer without a problem. Technically , you could fail a visual is all emissions items arnt in place....ie your AIR system.
Old Feb 15, 2003 | 02:02 PM
RamAir95TA's Avatar
I have !AIR, !EGR, !cat...think I will pass?
Old Feb 15, 2003 | 03:27 PM
Kain's Avatar
If you've got cats on, you should, but maybe. I've heard of LT4 hotcam cars failing.
Mine has no chance of passing.
Old Feb 15, 2003 | 03:45 PM
gd1996ss's Avatar
I had a stock 95, well airfoil, cai, hollowed cat, and flowmaster catback, and had trouble passing. Thats with new 02 sensors, plugs, oil, clean air filter, etc... I got it to pass by having the guy put the hc sniffer in the passenger side exhaust, since most of the exhaust went to the drivers side. The car was flowing more air than stock making it run rich. Nothing else done to the computer, etc... which may of helped.
With the cat, you should be ok, I would think. Obviously a visual inspection, it wouldn't pass. But not all palces look that good, or may let ya go. I can't see why it matters if they run clean without it.
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
