Will I pass emisisons sniffer w/ longtubes?
I want to put longtubes on, I know since the last time I got my car emission tested they just hooked it up to computer and put the thng on the exhaust, no one looked under my car. Im asking if I get longtubes w/ emissions hookups will I still pass? Is the only reason why people dont pass because the cat has been moved?
What are some cheap longtubes w/ emissions hookups?
Re: Will I pass emisisons sniffer w/ longtubes?
With the long tubes, you will need a different y-pipe which will make running cats. a little more difficult. Some people run a single cat at the end of the y-pipe and others, like myself, run dual cats in the y-pipe. Since I have a 97, I only have to pass the "plug-in" emissions test so I have it a little more easy. I just have the cats. there in case of a visual inspection so I am not quite sure how efficient they really are. Pacesetter does sell long tubes that have all of the emissions hookups if that is the route you go.
It also might be easier to buy the Pacesetter off-road y-pipe and a 3" cat. and put together the y-pipe that way. Otherwise, a shop will charge a good buck to completely fabricate a y-pipe. A shop in Naperville wanted 500.00 to make me a custom y-pipe with a catalyic converter.
2000GTP do you have any sound clips of your setup? i cant decide for the life of me if i want to ditch my single setup or not when i install my pacesetters.
Sorry I don't have an exhaust clip, I'm sure some others might though if you put up a new post or do a search. I can tell you though that although my exhaust sounds nice and it does get alot of complements, it is a little too tame because of the Magnaflow CB so I have a 3" cutout ready to go in.
I understand. I guess that that is my only way then. Will I still pass, as long as they dont do a visual and know exactly how many cats my car is suppose to have and where?
You can get a small bullet style muffler and throw that in where a cat should go, 9 out of 10 inspectors wont know the difference. Dunno about passing the sniffer though. A good tip is to retard timing 3-5 degrees, it will drop HC quite a bit and help you pass.
tdigger9899
Sep 7, 2015 10:56 AM
