Will I hit 350HP?
Old Dec 9, 2005 | 10:27 PM
Z28WannaB's Avatar
Will I hit 350HP?
I am in the process of building a 355 LT1 right now. I am using intake gasket matched heads, with a 3 angle valve job. A cam very similair to the hotcam 218/224 .4??/.4??, 1.6RR, pacesetter long tubes, cut-out, gutted CAT, electric waterpump, SLP CAI, throttle body bypass, airfoil, EGR delete, AIR delete, and a MADz28tune.
Is this enough to hit the 350 wheel hp mark? Or do I need a bigger cam?
Old Dec 9, 2005 | 11:30 PM
crAzy95z28's Avatar
Re: Will I hit 350HP?
possibly a bigger cam!
youll want bigger after you put that one in. also go bigger on the stall too..
3200 is the best
i am having a built 355 right now on stock heads/intake/tb with a 238/242 cam.
so yea
Old Dec 10, 2005 | 02:05 PM
96capricemgr's Avatar
You will easily hit that at the flywheel. If you want that at the flywheel you need to do more. The heads should be really ported and to be honest unless you used a VERY good shop the valvejob is probably worse tha stock because the stock one is rather good. You might consider 1.7 because that is rather low lift the heads should support more just make sure you get the right springs and check geometry.
Old Dec 10, 2005 | 03:47 PM
RE AND CHERYL's Avatar
Gasket matching is for people who like thinking their heads are way better than they are. Actually get the heads ported and you will be where you wnat to be with your current cam.
Old Dec 10, 2005 | 03:52 PM
Silver's Avatar
dude you're gonna fly past 350hp like **** with corn in it.
Old Dec 10, 2005 | 07:19 PM
MEAN LT1's Avatar
With all the supporting mods you have. Its a VERY good chance you'll hot the 350rwhp mark. Its been done alot. Inly thing I see that will get in your way is probably the stock t/b. Id go with a 52mm-58mm. But other than that its all up tot he tuner.
Old Dec 10, 2005 | 11:27 PM
Compstall's Avatar
I hit 326 w/ the Hotcam on stock tuning through stock manifolds so I'm sure it's possible.
Old Dec 11, 2005 | 01:00 AM
Those of you sure he will hit it are you considering the A4/M6 thing?
Old Dec 11, 2005 | 09:06 AM
MEAN LT1's Avatar
Hehe, now that you mention it. I totally forgot he was an auto. Let me restate my post. You'll most likely get 330rwhp. Most m6 cars with that setup see about 350rwhp.
Old Dec 12, 2005 | 11:25 PM
EastLa's Avatar
In my old '96Z I did a Hotcam, FLP long tubes, stock tuning, LT4 heads (out of the box), 1.6 rr, and stock LT4 intake. I did 363 rwhp and 333 rwtq. So yeah I think you'll get 350.
Old Jan 22, 2006 | 09:32 PM
Z28WannaB's Avatar
Do the extra cubes not count for anything?
I mean 330HP seems like what a stock 350 is gonna make. Should I even bother making it a 355?
Also I didn't think the TB made that big of a deal.
- Z28WAnnaB
Old Jan 22, 2006 | 10:19 PM
HaynesFaithZ28's Avatar
I have the same cam that you are thinking about installing and it is a good cam and I like it. The lift numbers (.495/.503) are with 1.5 rockers so with 1.6 you will be looking at .528/.536. The cam pulls hard around 2,500 to 5,500 with the stock tune and has a pretty nice lope. If I were you I would go with the XE 503 (220/230) because it would sound better and make a little more horsepower. I am probally going to install that one sometime. Also do you like your 2,400 stall converter and what kind do you have? Thanks and good luck, Chris!
Old Jan 23, 2006 | 12:39 AM
LT1-TA's Avatar
no... 5 CI is not going to give you any noticable difference... a 350 is jsut as good as a 355. 5 CI is nothing.. now if you were building a stroker... that is a compltly different game.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SergheiS
Sep 29, 2015 08:56 PM
alliance12364
Sep 23, 2015 12:40 PM
