will i get any lope out of a hot cam?
Old May 5, 2006 | 05:30 PM
'96WS-6's Avatar
Plan on doing a cam swap this summer after my transmission gets rebuilt by t56rebuilds.com, I was wondering if I plan on going ahead and gettin my heads ported and polished later on down the road, should I go with a hot cam or another cam that would maybe make more power? Keep in mind I need to not have the SES light on because I need to pass emissions...and does the hot cam have any lope, and does neone maybe have a vid to see how their LT1 runs with it Thanks!
Vince
Old May 5, 2006 | 05:33 PM
93redBirdMan's Avatar
Re: will i get any lope out of a hot cam?
yes, for how "small" it is, it has a nice lope
Old May 5, 2006 | 05:36 PM
j0n's Avatar
j0n
here in NJ with an obd2 vehicle(96+) there is no sniffer, just a readiness check of the pcm and a visual check for cats, and if you're unlucky you get the visual check under the hood for emissions equipment(AIR, EGR)
any tuner will be able to delete any codes that the pcm throws out in order to make you pass
Old May 5, 2006 | 09:04 PM
Temple's Avatar
Yes, the hotcam does have a nice lope to it....check out this site for some sounds of the hotcam.
www.ls1sounds.com
Old May 5, 2006 | 09:34 PM
luckyou03's Avatar
go bigger, go bigger, go bigger especially if your getting ported heads. For everyone that’s going to argue with me that knows nothing about this cam.. I'm running the hotcam right now. I have the LE1 cam sitting in my room ready to in
Old May 6, 2006 | 07:21 PM
Quickss96's Avatar
i have a video of my car with a hot cam i can send you, but i only had it in for about 2 months and then i was bored of it so i am now doing a big cam and a stroker
Old May 6, 2006 | 11:01 PM
1quickTA's Avatar
I have a hotcam and personally did not want much lope so I had my car tuned accordingly. However, if you want lope I have heard plenty of hotcam cars with a decent amount of lope. It depends on where your idle is set. Lower equals more lope, high idle is more like stock. Whoever tunes your pcm will be able to work with you to get you your desired lope. Good luck!
And as far as "this cam is too small" comments, it is all personal. I couldn't be happier with my hotcam because I did not want an aggressive cam and I am very happy with the output that my set-up has in terms of being a daily driver and reliability. Make sure you get the cam (or any part) that is RIGHT FOR YOU!
Old May 6, 2006 | 11:07 PM
Speed_Kills's Avatar
Doesn't the hotcam have a 108LSA. That's why it has lope to it
Old May 6, 2006 | 11:35 PM
Temple's Avatar
Nope...hotcam has a 112 LSA
Old May 6, 2006 | 11:38 PM
TY for the correction. For a DD. I wouldn't run more then a 114 LSA.. BUT.. If you spead out the duration to say 210/230 and run a 114 LSA. You'll have much less overlap and a better idle.
Old May 7, 2006 | 05:32 AM
Sparkz28ss's Avatar
the ASA hot cam is cut on a 110LSA
Old May 8, 2006 | 12:58 PM
SStrokerAce's Avatar
Originally Posted by Speed_Kills
4For a DD. I wouldn't run more then a 114 LSA.. BUT.. If you spead out the duration to say 210/230 and run a 114 LSA. You'll have much less overlap and a better idle.
What cho talking about Willis? NOOOOOOOOOOOO
Bret
Old May 8, 2006 | 07:28 PM
Dan Parker '96's Avatar
Lordy, if you tune it right the Hotcam will sound stock as it should. It is not a big cam but will provide a very nice boost over the stock cam. Provided you are willing to run up to about 6400rpm and shift a bit beyond.
Proper tuning will make 'er sound stock while surprising your idiot friends with CC306's and stock heads.
Old May 8, 2006 | 10:35 PM
biafula's Avatar
I got the hotcam, it's got a nice lope. Not as much as I was expecting, but you can definitely tell it's not a stock cam.
Old May 8, 2006 | 10:42 PM
my94blackz's Avatar
Hot cam in a lt1 is like a air foil in a throttle body, not worth the time, money, or whatever power gain.
But mine did have some lope
