Will This hold?
Old Aug 2, 2005 | 05:05 AM
96ta(nick)'s Avatar
Will This hold?
I'm going to go ahead and rebuild the motor and put some spray on it. I am wanting to spray 200 if i can get away with it.. My question is can i get away with some forged I-beam rods, forged pistons and the stock crank and studded stock mains? Also what parts do you suggest? I'm trying to go cheap but i don't want it falling apart on me...
Nick
Old Aug 2, 2005 | 07:42 AM
slomarao's Avatar
Re: Will This hold?
an aftermarket cast crank will be stronger than the stock one. I would use arp bolts in the whole motor for some extra insurance.
Old Aug 2, 2005 | 08:04 AM
jsetzer's Avatar
Re: Will This hold?
An extra 50shot is not a huge difference. I think that will hold just fine, but before going 200 you need a new pump, don't forget that in your setup.
Old Aug 2, 2005 | 08:07 AM
jsetzer's Avatar
Re: Will This hold?
And go to bed already will you?
Old Aug 2, 2005 | 08:20 AM
Gripenfelter's Avatar
Re: Will This hold?
You don't need 4 bolt mains to run a 200 shot. You need good tuning, good gas, and no detonation.
Old Aug 2, 2005 | 09:22 AM
89385formula's Avatar
Re: Will This hold?
Thats the same setup I am going with. The stock crank is pretty strong man, with a good balance, lightweight forged pistons and a good lightweight rod you will have taken alot of stress off the crank. I am spraying a 150 shot with this setup once its all back together. For rods Eagle or Scat's are reaonalby priced, come with ARP bolts, and are plenty enough. I went with Mahle pistons, because they are already coated when you get them, come with rings, and i have heard alot of good things about them. Also like previously stated a good tune, good gas, and a timing retard and other safety features is what you need to spray.
Kyle
Old Aug 2, 2005 | 03:02 PM
96ta(nick)'s Avatar
Re: Will This hold?
So will the I-Beams hold it or do i need to go with some H-beams?
Old Aug 2, 2005 | 09:42 PM
Re: Will This hold?
I have been informed multiple times that a Scat or Eagle I beam should be more than adequate with a 355. The Scat I beams are 4340 forged and are very strong...will be plenty strong. if you want more reassurance you could go ahead and upgrade the rod bolts, but H beams aren't necessary. Also the h beams are a good bit heavier as well.
LT14LIFE
Nov 15, 2015 06:22 PM
PopoFormula
Oct 12, 2015 04:19 PM
CARiD
Sep 30, 2015 05:44 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
350350
14
Aug 11, 2015 12:03 PM
