Will this hit 350HP at the wheels
Old Mar 11, 2004 | 11:33 PM
Eric85's Avatar
ok i am about to order my cam and rockers and other parts for my motor swap. here is the setup.
233/239 duration, .569"/.577", 112lsa
1.6 magnum roller rockers
Comp R lifters
Hardened pushrods
CC 977 springs
Titanium retianers
Zexel torsen posi
3.73 gears
1 5/8 Sanderson shorty headers (remmber i have an s10)
2.5 inch exhust with super turbo mufflers dumped at the axle
cloyes double roller
Meizere electric H20 Pump
Walbro 255 LPH in tank
What do you guys think. Im really hoping to do about 340-350 HP at the wheels with a good tune from Ion.
Old Mar 11, 2004 | 11:37 PM
sc93's Avatar
I'd say its possible
auto or 6 speed?
Old Mar 11, 2004 | 11:40 PM
Eric85's Avatar
auto and i wont be running a stall for maybe 4-5 months after the swap. It will probably be a dog off the line.
Old Mar 11, 2004 | 11:50 PM
25thBird's Avatar
not to put you down, but half of the stuff listed on there will not give you major horse power gaing, or any horse power gain for that matter... aside from the cam and the headers, you won't get much gains from the other stuff. It can probably get you 350 at the flywheel, but i don't think that would get you 350 at the rear wheels. Also because your S10 is not a V8, right?
Old Mar 11, 2004 | 11:53 PM
25thBird's Avatar
sorry i didn't read the part on the lt1 swap on your sig, i think you'll be closer to 315-320 at the rears...
Old Mar 11, 2004 | 11:55 PM
atljar's Avatar
340-345 would be my guess. You have the 7.5 or the bigger 8.5 rear? The blazer rear will eat a little more HP, but is well worth the strength IMO.
Anyways, key is in the tuning!
97WS6SCharged's Avatar
With that cam he's probably looking at a good solid 350 at the wheels, maybe a few more. Give the heads a good, quality port job and you'll probably hit 400 at the wheels.
Old Mar 12, 2004 | 12:04 AM
Eric85's Avatar
Yea i know some of the stuff i listed wont do much but i just listed them to give you guys an idea of my setup. Anyways i am hoping for 340-350 at the wheels with a good tune.
Also will the truck and motor run like poo without a stall?
*EDIT* the truck has the 7.5 rear
Old Mar 12, 2004 | 12:08 AM
25thBird's Avatar
actually, i would say port the heads along and you'll be good at 350..
Old Mar 12, 2004 | 12:09 AM
It will definately run better with a stall, you might get a little surging at idle and/or the truck may try to run through the brakes without a stall.
Oh, if you want a halfway decent rear for that truck, find a rearend out of a 4x4 blazer and stick it under there. It'll be a little bit wider than what you have, but you probably won't hook up enough to break it anyway.
Old Mar 12, 2004 | 12:11 AM
Eric85's Avatar
yea i plan on getting a 8.5 out of a ZR2 or out of a GN but is 350 out of the question here? Madwolf made 346 i believe with this same cam.
Old Mar 12, 2004 | 12:23 AM
Honestly, even if you only make 300 to the wheels, you aren't going to have enough traction anyways. What's the big deal about 350 at the wheels?
Old Mar 12, 2004 | 12:34 AM
Eric85's Avatar
why do you say i wont have traction?
Old Mar 12, 2004 | 12:47 AM
Well, if it's anything like the S10 I had, it won't have traction.
I had a built 406/700R4 in an 84 S10. If I got on it, the rear tires would just spin instead of getting any bite so the rearend never got a big enough shock to break it.
Old Mar 12, 2004 | 12:54 AM
Eric85's Avatar
well one thing is that this truck will never see the drag strip. Mostly the 350 HP is for bragging rights and some street racing. Later on down the road i will be getting a beefy 4 link out back with a 8.5 rear so i can beef the motor up some so that the rear can handle it.
akwa
Apr 5, 2015 05:09 PM
NewsBot
Mar 13, 2015 07:15 AM
mark0006
Feb 3, 2015 05:12 PM
ChrisFrez
Nov 30, 2014 08:41 AM
